LimeSDR XTRX v1.3 Board
Introduction
LimeSDR XTRX v1.3 Board Key Features
LimeSDR XTRX is Small form factor mini PCIe expansion card Software Defined Radio (SDR) board. It provides a hardware platform for developing and prototyping high-performance and logic-intensive digital and RF designs based on Xilinx’s XC7A50T-2CPG236I FPGA and Lime Microsystems transceiver chipsets.
LimeSDR XTRX is a building block for any Massive MIMO configuration from 2Tx2R to 32Tx32R for very high data rate applications. Hence, it could be used in conjunction with any digital processors (ASICs, GPPs and GPUs) of varying level of performance in terms of speed, power dissipation and cost to fit any air interface from narrowband to broadband signals. The board is designed for maximum scalability in terms of the following parameters:
  • Frequency and Bandwidth: The heard of the board is the Lime Transceiver RFIC (LMS7002) providing frequency flexibility up to 3.8GHz and bandwidths of over 100MHz.
  • Baseband Interface: A significant level of digital circuitry resides within the LMS7002 and accompanying Xilinx for the implementation of the key physical layer radio functions including filtering, decimation, interpolation and flexible interface such as PCIe and SerDes to name a few.
../_images/LimeSDR-XTRX_v1.3_3D_top.png
Figure 1: LimeSDR XTRX v1.3 board top view
../_images/LimeSDR-XTRX_v1.3_3D_bot.png
Figure 2: LimeSDR XTRX v1.3 board bottom view
LimeSDR XTRX board features:
  • RF and BB parameters:
    • Configuration: MIMO (2xTX, 2xRX)
    • Frequency range: 30 MHz – 3.8 GHz
    • Bandwidth: 30.72 MHz
    • Sample depth: 12 bit
    • Sample rate: 30.72 MSPS
    • Transmit power: max 10 dBm (depending on frequency)
  • USB 2.0 controller: Microchip USB3333E-GL
  • FPGA: board is designed based on Xilinx Artix-7 XC7A50T-2CPG236I FPGAs in 236-ball CSBGA package. Xilinx XC7A50T-2CPG236I features are:
    • 236-pin CSBGA package (10mm x 10mm, 0.5mm)
    • 52160 LUTs logic capacity
    • 2700 Kb Embedded Memory
    • 600 Kb distributed RAM
    • 120x 18x18-bit multipliers
    • 5x PLLs and 4x DLLs
    • 106 IOs
    • FPGA configuration via JTAG
  • RF transceiver: Lime Microsystems LMS7002M
  • EEPROM Memory: 128Kb EEPROM for LMS MCU firmware (optional); 128Kb EEPROM for FPGA data (optional)
  • FLASH Memory: 256Mb Flash memory for FPGA configuration
  • Temperature sensor: TMP1075NDRLR
  • General user inputs/outputs:
    • 2x Green LEDs
    • 4x GPIOs 3.3V in GPIO connector
    • 1x GPIO in Baseband connectors
  • Connections:
    • USB 2.0 (Micro-B) socket
    • Coaxial RF (U.FL female) connectors
    • FPGA GPIO 8-pin FPC connector
    • FPGA JTAG connector (unpopulated)
    • Mini PCIe edge connector
    • RF Baseband 15-pin FPC connectors
  • Clock system:
    • 26.00MHz on board VCTCXO
    • VCTCXO may be tuned by on board DAC
    • Reference clock input and output connectors (U.FL and mPCIe)
  • Board size: 50.8mm x 29.7mm (PCIe Mini card form factor)
  • Board power sources: USB connector (5V) or mini PCIe (3.3V)
For more information on the following topics, refer to the respective documents:
Board Overview
One of the key elements of LimeSDR XTRX board is the Xilinx Artix-7 (XC7A50T-2CPG236I) FPGA. It’s main function is to transfer digital data between LMS7002M RF transceiver and PC through a mini PCIe edge connector or Serial connection to another FPGA board. The block diagram for LimeSDR XTRX board is presented in the Figure 3.
../_images/LimeSDR-XTRX_v1.3_diagrams_BD.png
Figure 3: LimeSDR XTRX v1.3 board block diagram
This section contains component location description on the board. LimeSDR XTRX board picture with highlighted connectors and main components are presented in Figure 4 and Figure 5, respectively.
../_images/LimeSDR-XTRX_v1.3_components_top.png
Figure 4: LimeSDR XTRX v1.3 board top connectors and main components
../_images/LimeSDR-XTRX_v1.3_components_bot.png
Figure 5: LimeSDR XTRX v1.3 board bottom connectors and main components
Table 1. Board components
Featured Devices
Board Reference
Type
Description
IC1
RF transceiver
IC7
FPGA
Xilinx Artix-7(XC7A50T-2CPG236I)
IC19
USB 3.0
microcontroller
Microchip USB 2.0 to transceiver chip USB3333E-GL
Miscellaneous devices
IC9
IC
Temperature sensor TMP1075NDRLR
IC16
IC
SIM Card Interface NVT4555UKZ
Configuration, Status and Setup Elements
X9
JTAG chain
connector
FPGA programming connector on the PCB bottom side
(compatible with Molex 788641001 connector)
LED1, LED2
Status LEDs
User defined FPGA indication LEDs
General User Input/Output
X12
Pin header
8-pin FPC connector
Memory Devices
IC2
IC
I²C EEPROM Memory 128Kb (16 x 8), connected to LMS7002M RF transceiver I2C bus
IC13
IC
I²C EEPROM Memory 128Kb (16K x 8), connected to FPGA I2C bus
IC18
IC
SPI Flash Memory 256 Mb (32M x 8) connected to FPGA SPI
Communication Ports
X11
USB 2.0
USB 2.0 Micro-B socket
X10
mini PCIe
mini PCI Express Card Edge connector
Clock Circuitry
XO1
VCTCXO
26.00 MHz Voltage Controlled Temperature Compensated Crystal Oscillator
IC17
IC
16 bit DAC for VCTCXO (XO1) frequency tuning (default)
IC11
IC
GNSS Receiver module
IC8
IC
Clock buffer LMK00105
IC15
IC
Analogue switch
IC20
IC
Analogue switch
X7
U.FL connector
Reference clock input/output (CLK)
X6
U.FL connector
1PPS input
X5
U.FL connector
GNSS (active) antenna connector
Power Supply
IC22
IC
Four-output switching regulator LP8758A1E0YFFR
IC31
IC
IC21
IC
Linear regulator LD39100PUR
IC26
IC
IC29
IC
IC32
IC
LimeSDR XTRX Board Architecture
More detailed description of LimeSDR XTRX board components and interconnections is given in the following sections of this chapter.
LMS7002M RF transceiver digital connectivity
The interface and control signals are described below:
  • Digital Interface Signals: LMS7002 is using data bus LMS_DIQ1_D[11:0] and LMS_DIQ2_D[11:0], LMS_EN_IQSEL1 and LMS_EN_IQSEL2, LMS_FCLK1 and LMS_FCLK2, LMS_MCLK1 and LMS_MCLK2 signals to transfer data to/from the XILINX FPGA. Indices 1 and 2 indicate transceiver digital data PORT-1 or PORT-2. Any of these ports can be used to transmit or receive digital IQ data. By default PORT-1 is selected as transmitter port and PORT-2 is selected as receiver port. The FCLK# is input clock and MCLK# is output clock for the LMS7002M transceiver. TXNRX signals are used to indicate ports direction. Please refer to LMS7002M transceiver datasheet page 12-13. [link] for the LMS7002M interface timing.
  • LMS Control Signals: these signals are used for the following functions within the LMS7002 RFIC: * LMS_RXEN, LMS_TXEN – receiver and transmitter enable/disable signals connected to FPGA Bank 14 (3.3V). * LMS_RESET – LMS7002M reset is connected to FPGA Bank 14 (3.3V).
  • SPI Interface: LMS7002M transceiver is configured via 4-wire SPI interface: FPGA_SPI_SCLK, FPGA_SPI_MOSI, FPGA_SPI_MISO, FPGA_SPI_LMS_SS. The SPI interface is connected to FPGA Bank 14 (3.3V).
  • LMS I2C Interface: can be used for LMS EEPROM content modification or debug purposes. The signals LMS_I2C_SCL and LMS_I2C_DATA are connected to EEPROM.
Table 2. LMS7002M RF transceiver digital interface pins
Chip pin (IC1)
Chip reference (IC1)
Schematic signal name
FPGA pin
FPGA I/O standard
Description
E5
xoscin_tx
LMS_TxPLL_CLK
Connected to reference clock
AB34
MCLK1
LMS_MCLK1
L17
3.3V
AA33
FCLK1
LMS_FCLK1
G19
3.3V
V32
TXNRX1
LMS_TXNRX1
V15
3.3V
U29
TXEN
LMS_TXEN
W19
3.3V
Y32
ENABLE_IQSEL1
LMS_EN_IQSEL1
P19
3.3V
AG31
DIQ1_D0
LMS_DIQ1_D0
J17
3.3V
AF30
DIQ1_D1
LMS_DIQ1_D1
H17
3.3V
AF34
DIQ1_D2
LMS_DIQ1_D2
H19
3.3V
AE31
DIQ1_D3
LMS_DIQ1_D3
K17
3.3V
AD30
DIQ1_D4
LMS_DIQ1_D4
G17
3.3V
AC29
DIQ1_D5
LMS_DIQ1_D5
V16
3.3V
AE33
DIQ1_D6
LMS_DIQ1_D6
J19
3.3V
AD32
DIQ1_D7
LMS_DIQ1_D7
M19
3.3V
AC31
DIQ1_D8
LMS_DIQ1_D8
P17
3.3V
AC33
DIQ1_D9
LMS_DIQ1_D9
N19
3.3V
AB30
DIQ1_D10
LMS_DIQ1_D10
U17
3.3V
AB32
DIQ1_D11
LMS_DIQ1_D11
U16
3.3V
AM24
xoscin_rx
LMS_RxPLL_CLK
P34
MCLK2
LMS_MCLK2
W5
3.3V
R29
FCLK2
LMS_FCLK2
W6
3.3V
U31
TXNRX2
LMS_TXNRX2
U5
3.3V
V34
RXEN
LMS_RXEN
W18
3.3V
R33
ENABLE_IQSEL2
LMS_EN_IQSEL2
W7
3.3V
H30
DIQ2_D0
LMS_DIQ2_D0
W2
3.3V
J31
DIQ2_D1
LMS_DIQ2_D1
U2
3.3V
K30
DIQ2_D2
LMS_DIQ2_D2
U3
3.3V
K32
DIQ2_D3
LMS_DIQ2_D3
V3
3.3V
L31
DIQ2_D4
LMS_DIQ2_D4
V4
3.3V
K34
DIQ2_D5
LMS_DIQ2_D5
V2
3.3V
M30
DIQ2_D6
LMS_DIQ2_D6
V5
3.3V
M32
DIQ2_D7
LMS_DIQ2_D7
V4
3.3V
N31
DIQ2_D8
LMS_DIQ2_D8
V8
3.3V
N33
DIQ2_D9
LMS_DIQ2_D9
U4
3.3V
P30
DIQ2_D10
LMS_DIQ2_D10
U8
3.3V
P32
DIQ2_D11
LMS_DIQ2_D11
U7
3.3V
U33
CORE_LDO_EN
LMS_CORE_LDO_EN
W17
3.3V
E27
RESET
LMS_RESET
U19
3.3V
D28
SEN
FPGA_SPI_LMS_SS
W13
3.3V
SPI interface
C29
SCLK
FPGA_SPI_SCLK
W14
3.3V
SPI interface
F30
SDIO
FPGA_SPI_MOSI
W16
3.3V
SPI interface
F28
SDO
FPGA_SPI_MISO
W15
3.3V
SPI interface
D26
SDA
LMS_I2C_SDA
Connected to EEPROM
C27
SCL
LMS_I2C_SCL
Connected to EEPROM
RF network control signals
LimeSDR XTRX RF network contains matching networks, RF switches, loopback variable attenuator and U.FL connectors (X1, X3 - TX and X2, X4 - RX) as shown in Figure 6.
../_images/LimeSDR-XTRX_v1.3_diagrams_RFFE.png
Figure 6. LimeSDR XTRX v1.3 RF diagram
LMS7002M RF transceiver TX and RX ports has dedicated matching network which determines the working frequency range. More detailed information on LMS7002M RF transceiver ports and matching network frequency ranges is listed in the Table 3.
Table 3. LMS7002M RF transceiver ports and matching networks frequency ranges
Frequency range
TX1_1, TX2_1
2 GHz - 2.6 GHz
TX1_2, TX2_2
30 MHz - 1.9 GHz
RX1_H, RX2_H
2 GHz - 2.6 GHz
RX1_W, RX2_W
700 MHz - 900 MHz
RX1_L, RX2_L
300 MHz – 2.2 GHz
RF network switches are controlled via 2.4V logic signals. This is achieved by resistor dividers connected between FPGA (TX_SW, RX_SW1, RX_SW2) and switch control pin (TX_SW_DIV, RX_SW1_DIV, RX_SW2_DIV). RF network control signals are described in the Table 4.
Table 4. RF network control signals
Component
I/O standard
FPGA pin
Description
SKY13330-397LF(IC5 and IC6)
TX_SW/TX_SW_DIV
3.3V
P1
FPGA 3.3V logic level signal divided to 2.4V logic level.
SKY13414-485LF(IC3 and IC4)
RX_SW1/RX_SW1_DIV
3.3V
K3
RX_SW2/RX_SW2_DIV
3.3V
J3
LMS7002M baseband connectors
LMS7002M RF transceiver (IC1)) baseband signals (RX ADC and TX DAC) can be accessed via 0.3mm pitch 15 pin FPC connectors (X13 and X8). RX DAC connector pinout is shown in Table 5. TX ADC connector pinout is shown in Table 6.
Table 5. LMS7002 base band TX DAC connector (X13)
Pin
Description
1
GND
Ground
2
DAC1Q_P
Channel 1 quadrature signal differential positive
3
DAC1Q_N
Channel 1 quadrature signal differential negative
4
GND
Ground
5
DAC1I_P
Channel 1 in-phase signal differential positive
6
DAC1I_N
Channel 1 in-phase signal differential negative
7
GND
Ground
8
GPIO13
General purpose input/output (FPGA pin T17)
9
GND
Ground
10
DAC2Q_P
Channel 2 quadrature signal differential positive
11
DAC2Q_N
Channel 2 quadrature signal differential negative
12
GND
Ground
13
DAC2I_P
Channel 2 in-phase signal differential positive
14
DAC2I_N
Channel 2 in-phase signal differential negative
15
GND
Ground
Table 6. LMS7002 base band RX ADC connector (X8)
Pin
Description
1
GND
Ground
2
ADC1I_P
3
ADC1I_N
4
GND
Ground
5
DAC1Q_P
6
DAC1Q_N
7
GND
Ground
8
GPIO13
9
GND
Ground
10
ADC2I_P
11
ADC2I_N
12
GND
Ground
13
ADC2Q_P
14
ADC2Q_N
15
GND
Ground
USB 2.0 controller
LimeSDR XTRX could be powered and programmed via USB 2.0 by connecting it to micro-B port or mini PCIe connector. USB 2.0 is implemented using Microchip USB3333E-GL transceiver [link]. The controller signals description are shown below:
  • USB_D[7:0] – 8-bit data interface is connected to FPGA.
  • USB_NRST, USB_NXT, USB_DIR, USB_STP – interface control signals.
  • USB_CLK – interface clock. Clock from transceiver is fed to XILINX FPGA.
  • USB_26M – interface clock. Clock from FPGA is fed to Lime transceiver.
USB 2.0 controller pins, schematic signal names, FPGA interconnections and I/O standard are described in Table 7.
Table 7. USB 2.0 controller interface
Chip pin (IC19)
Chip reference (IC19)
FPGA pin
I/O standard
C2
RESETB
USB_NRST
M18
3.3V
E3
DAT7
USB_D7
C15
3.3V
E4
DAT6
USB_D6
A14
3.3V
E5
DAT5
USB_D5
A15
3.3V
D4
DAT4
USB_D4
B15
3.3V
D5
DAT3
USB_D3
A16
3.3V
C4
DAT2
USB_D2
B16
3.3V
C5
DAT1
USB_D1
A17
3.3V
B4
DAT0
USB_D0
B17
3.3V
A3
STP
USB_STP
C17
3.3V
B5
NXT
USB_NXT
A18
3.3V
A4
DIR
USB_DIR
B18
3.3V
A5
CLKOUT
USB_CLK
C16
3.3V
A2
REFCLK
USB_26M
E19
3.3V
Indication LEDs
LimeSDR XTRX board comes with two green indicator LEDs. These LEDs are soldered on the top of the board near the USB Micro-B connector.
../_images/LimeSDR-XTRX_v1.3_components_LEDs.png
Figure 7. LimeSDR XTRX indication LEDs (top)
LEDs are connected to FPGA hence their function may be programmed according to the user requirements. Default LEDs configuration and description are shown in Table 8.
Table 8. Default LEDs configuration
Board Reference
Schematic name
Board label
FPGA pin
Description
LED1
FPGA_LED1
LED1
N18
User defined
LED2
FPGA_LED2
LED2
V19
User defined
Low speed interfaces
FPGA_SPI pins, schematic signal names, FPGA interconnections and I/O standards/levels are shown in Table 9.
Table 9. FPGA_SPI interface pins
FPGA pin
I/O standard
Comment
FPGA_SPI_SCLK
W14
3.3V
Serial Clock (FPGA output)
FPGA_SPI_MOSI
W16
3.3V
Data (FPGA output)
FPGA_SPI_MISO
W15
3.3V
Data (FPGA input)
FPGA_SPI_LMS_SS
W13
3.3V
IC1 (LMS7002 (IC1)) SPI slave select (FPGA output)
FPGA_CFG_SPI pins, schematic signal names, FPGA interconnections and I/O standards are shown in Table 10.
Table 10. FPGA_CFG_SPI interface pins
FPGA pin
I/O standard
Comment
FPGA_CFG_CCLK
C11
3.3V
FPGA_CFG_CS
K19
3.3V
IC18 SPI slave select (FPGA output)
FPGA_CFG_D00
D18
3.3V
FPGA_CFG_D01
D19
3.3V
FPGA_CFG_D02
G18
3.3V
FPGA_CFG_D03
F18
3.3V
FPGA_I2C1 (temperature sensor, EEPROM, CLK DAC, switching regulator) and FPGA_I2C2 (switching regulator) interface slave devices and related information are given in Table 11.
Table 11. FPGA_I2C1 and FPGA_I2C2 interfaces pins
I2C slave device
Slave device
Inteface
I2C address
I/O standard
Comment
IC9
Temperature sensor
FPGA_I2C1
1 0 0 1 0 1 1 RW
3.3V
TMP1075NDRLR
IC13
EEPROM
1 0 1 0 0 0 0 RW
3.3V
M24128
IC17
CLK DAC
1 0 0 1 1 0 0 RW
3.3V
AD5693RACPZ
IC22
Switching regulator
1 1 0 0 0 0 0 RW
3.3V
LP8758A1E0YFFR
IC31
Switching regulator
FPGA_I2C2
1 1 0 0 0 0 0 RW
3.3V
LP8758A1E0YFFR
To debug FPGA design, flash bitstream to FPGA and/or Flash memory JTAG X9 connector is used. It is located on the PCB bottom side (see Figure 5: LimeSDR XTRX v1.3 board bottom connectors and main components) and is compatible with Molex 788641001 connector. JTAG connector pins, schematic signal names, FPGA interconnections and I/O standards are listed in Table 12.
Table 12. JTAG connector X9 pins
Connector pin
FPGA pin
I/O standard
Comment
1
TDO
W8
3.3V
Test Data Out
2
TDI
W10
3.3V
Test Data In
3
TMS
W9
3.3V
Test Mode Select
4
VCC3P3
Power (3.3V)
5
TCK
C8
3.3V
Test Clock
6
GND
Ground
GPIO connectors
Four GPIOs from FPGA are connected to 8 pin FPC connector (X12). GPIOS are separated by ground pins. Additional pin is dedicated for power as shown in Table 13.
Table 13. FPGA GPIO connector (X12) pins
Connector pin
FPGA pin
I/O standard
Comment
1
VCC3P3
3.3V
Power (3.3V)
2
GPIO9_P
H1
3.3V
3
GND
3.3V
Ground
4
GPIO9_N
J1
3.3V
5
GND
3.3V
Ground
6
GPIO11_P
K2
3.3V
7
GND
3.3V
Ground
8
GPIO11_N
L2
3.3V
Clock Distribution
LimeSDR XTRX board clock distribution block diagram is as shown in Figure 8.
../_images/LimeSDR-XTRX_v1.3_diagrams_clock.png
Figure 8. LimeSDR XTRX v1.3 board clock distribution block diagram
LimeSDR XTRX board features an on board 26.00 MHz VCTCXO as the reference clock for LMS7002M RF transceiver and FPGA PLLs.
Rakon E6982LF 26.00 MHz voltage controlled temperature compensated crystal oscillator (VCTCXO) is the clock source for the board. VCTCXO frequency may be tuned by using 16 bit DAC (IC17). Main VCTCXO parameters are listed in Table 14.
Table 14. Rakon E6982LF VCTCXO main parameters
Frequency parameter
Value
Calibration (25°C ± 1°C)
± 1 ppm max
Stability (-40 to 85 °C)
± 0.2 max
Long term stability (1 year, 3 years)
± 1 ppm max, ± 2 ppm max
Control voltage range
0.5V .. 2.8V
Frequency tuning
± 3 ppm
Slope
+4 ppm/V
Analogue switch gives option to select clock source for RF transceiver and FPGA from buffered VCTCXO onboard clock XO1 (CLK_XO) and external U.FL (X7)/mPCIe (X10) sources (CLK_IN). Buffered VCXO clock (LMK_CLKOUT3 and LMK_CLKOUT4) can also be fed to other board using U.FL (X7)/mPCIe (X10)connectors.
The board clock lines and other related signals/information are listed in Table 15.
Table 15. LimeSDR XTRX main clock lines
Source
Destination
I/O standard
CLK_XO
(VC)TCXO (XO1)
Analog mux
Clipped sinewave
CLK_IN
CLK_EXT or PCIE_CLK_IN
Analog mux
3.3V
CLK_EXT
U.FL connector
CLK_IN
3.3V
PCIE_CLK_IN
mPCIe connector
CLK_IN
3.3V
LMS_TxPLL_CLK
Analog mux
RF transceiver
1.8V
LMS_RxPLL_CLK
Analog mux
RF transceiver
1.8V
FPGA_CLK
Analog mux
FPA
3.3V
LMK_CLKOUT3
Analog mux
External
3.3V
LMK_CLKOUT4
Analog mux
External
3.3V
LMS_MCLK1
RF transceiver
FPGA
3.3V
LMS_FCLK1
FPGA
RF transceiver
3.3V
LMS_MCLK2
RF transceiver
FPGA
3.3V
LMS_FCLK2
FPGA
RF transceiver
3.3V
PCIE_REF_CLK_P/N
PCIe
FPGA
1PPSO_GPIO2(1P)
FPGA
mPCIe
3.3V
1PPSI_GPIO1(1N)
External
FPGA
3.3V
1PPS_IN
External
FPGA
3.3V
GNSS_1PPS
GNSS
FPGA
3.3V
LimeSDR XTRX board communicates with the host system via mPCIe connector. LimeSDR XTRX mini PCIe connector pinout and signals according to the specification is given in Table 16.
Table 16. Mini PCIe x1 edge connector pinout
Pin
Mini PCIe x1 Specification
LimeSDR XTRX
Description
1
Wake#
NC
Not connected
2
3.3 Vaux
VCC3P3_MPCIE
Main power input 3.3V (VCC3P3_MPCIE)
3
COEX1
1PPSI_GPIO1(1N)
External 1PPS input or GPIO1 or GPIO1N, CMOS 3.3 V
4
GND
GND
Ground
5
COEX2
1PPSO_GPIO2(1P)
GPS 1PPS output or GPIO2 or GPIO1P, CMOS 3.3 V
6
GND
NC
Not connected
7
CLKREQ#
CLK_REQUEST#
Tied to GND through resistor 330 Ohm
8
UIM PWR
UIM_VCC
User Identity Module interface power 1.8 V or 3V
9
GND
GND
Ground
10
UIM_DATA
UIM_DIO
User Identity Module interface data 1.8 V or 3V
11
REFCLK-
PCI_REF_CLK_N
PCI Express Reference clock differential pair negative signal
12
UIM_CLK
UIM_CLK
User Identity Module interface clock 1.8 V or 3V
13
REFCLK+
PCI_REF_CLK_P
PCI Express Reference clock differential pair positive signal
14
UIM_RESET
UIM_RST
User Identity Module interface reset 1.8 V or 3V
15
GND
GND
Ground
16
UIM_VPP
NC
Not connected
17
Reserved
TDD_GPIO3_N
TDD TX Enable output or GPIO3N or GPIO4, CMOS 3.3V
18
GND
GND
Ground
19
Reserved
CLK_IN
External clock input 3.3 V
20
W_DISABLE#
TDD_GPIO3_P
GPIO3P or GPIO3 (or Pair of TDD TX Enable), CMOS 3.3V
21
GND
GND
Ground
22
PERST#
PCIE_PERST#
PCI Express interface reset
23
PERn0
PCI_TX0_N
PCI Express interface output differential pair negative signal
24
3.3Vaux
NC
Not connected
25
PERp0
PCI_TX0_P
PCI Express interface output differential pair positive signal
26
GND
GND
Ground
27
GND
GND
Ground
28
1.5Volt
NC
Not connected
29
GND
GND
Ground
30
SMB CLK
SMB_CLK
Clock output (CLK_OUT)
31
PETn0
PCI_RX0_N
PCI Express interface input differential pair negative signal
32
SMB Data
SMB_DATA
GPIO8
33
PETp0
PCI_RX0_P
PCI Express interface input differential pair positive signal
34
GND
GND
Ground
35
GND
GND
Ground
36
USB_D-
USB_D_N
USB 2.0 data differential pair negative signal
37
GND
GND
Jumper to GND. Connected by default
38
USB_D+
USB_D_P
USB 2.0 data differential pair positive signal
39
3.3Vaux
PCI_TX1_N
40
GND
GND
Ground
41
3.3Vaux
PCI_TX1_P
42
LED_WWAN#
LED_WWAN#_GPIO5
Output for LED WWAN (Negative) or GPIO5 3.3 V
43
GND
GND
44
LED_WLAN#
LED_WLAN#_GPIO6
45
Reserved
PCIE_RESERVED
Connected to FPGA (V7)
46
LED_WPAN#
LED_WPAN#_GPIO7
Output for LED WPAN (Negative) or GPIO7 3.3 V
47
Reserved
PCI_RX1_N
48
1.5Volt
NC
Not connected
49
Reserved
PCI_RX1_P
50
GND
GND
Ground
51
Reserved
PCIE_W_DISABLE2#
Connected to FPGA (W3)
52
3.3Vaux
VCC3P3_MPCIE
Power Distribution
As indicated, LimeSDR XTRX board may be powered via USB port (5V) or mini PCIe edge connector (3.3V). LimeSDR XTRX board power delivery network consists of different power rails/voltages, filters and power sequences. LimeSDR XTRX board power distribution block diagram is presented in Figure 9.
../_images/LimeSDR-XTRX_v1.3_diagrams_power.png
Figure 9. LimeSDR XTRX v1.3 board power distribution block diagram
Differencies from LimeSDR XTRX v1.2
Changes introduction
LimeSDR XTRX v1.3 board is designed using LimeSDR XTRX v1.2 (r1) project as base.
The reference clock structure has been changed, replacing the separate general-purpose buffers with one dedicated clock buffer. Added the ability to supply an external 3.3V voltage to the lines of that voltage, bypassing the switching regulators.
Also, in this project we started using Altium Variants function to more conveniently manage components assembly info, alternatives and to more easily generate manufacturing information such as BOM and PCB views.
RF transceiver changes
A single clock signal (LMS_CLK) for both TX and RX PLLs was replaced by two separate clock signals (LMS_TxPLL_CLK for TX PLL and LMS_RxPLL_CLK for RX PLL) as shown in Figure 10.
../_images/LimeSDR-XTRX_v1.3_RF_changes.png
Figure 10. Separated LMS7002M RX and TX PLLs clocks schematics
FPGA changes
Since this is new version of the board hardware version (HW_VER) was increased from 2 to 3. This change allows software to automatically distinguish between older and newer board versions. Also bill of materials version (BOM_VER) was reverted back from 1 to 0 (populated R49) to indicate that this is original LimeSDR XTRX v1.3 state. New BOM_VER and HW_VER schematics are given in Figure 11.
../_images/LimeSDR-XTRX_v1.3_BOM_changes.png
Figure 11. FPGA BOM_VER and HW_VER schematics changes
Miscellaneous changes
To make schematic signal naming more consistent added PCIE_CLK_IN signal name was addedd to mPCIe connectors (X10) pin 19. Also CLK_OUT signal name was changed to LMK_CLKOUT4, due to changes in clock network described in clock changes below.
PCIE_PERST# signals pulldown resistor (R90) was removed from schematics.
All described mPCIe schematic changes are shown in Figure 12.
../_images/LimeSDR-XTRX_v1.3_mPCIe_changes.png
Figure 12. mPCIe connector changes
To make schematics easier to read mechanical components shown in Figure 13 were moved from 05_LMS7002M_RF sheet to 09_Misc sheet.
../_images/LimeSDR-XTRX_v1.3_Mech_changes.png
Figure 13. Mechanical components
Clock changes
Clock buffers and XO DAC were changed. Resulting new clock diagram is shown in Figure 14.
Figure 14. LimeSDR XTRX v1.3 board clock block diagram
The new clock buffer is LMK00105. It generates clock signals in 1.8V and 3.3V logic. LMK00105 schematics are given in Figure 15.
../_images/LimeSDR-XTRX_v1.3_buff_changes.png
Figure 15. New clock buffer LMK00105 schematics
Changed XO DAC from AD5693RACPZ-1RL7 (A grade, INL +-8LSB, internal reference, VLOGIC) to AD5693BCPZ-RL7 (B grade, INL +-3LSB, no internal reference, LDAC). Also removed R69, and populated R68 to tie LDAC pin low. This change make so DAC updates when new data is written to the input register. XO DAC schematic changes are shown in Figure 16.
../_images/LimeSDR-XTRX_v1.3_dac_changes.png
Figure 16. XO DAC schematics changes
Power changes
It is now possible to connect VCC_EXT directly to VCC3P3 and VCC_CLK accordingly as shown in Figure 17.
Figure 17. LimeSDR XTRX v1.3 board clock power distribution diagram
3.3 V Power signals generated by switching regulators were renamed from VCC3P3 to VCC3P3_SW and VCC_CLK to VCC_CLK_SW. And now can be discontented from main VCC3P3 and VCC_CLK power signals by removing R201 and R202. Also removed VCC1P8_CLK power net and inductor. All switching regulators schematic changes are shown in Figure 18.
../_images/LimeSDR-XTRX_v1.3_swreg_changes.png
Figure 18. Switching regulators schematics changes
Added power rails source selection for VCC3P3 and VCC_CLK. By default switching regulator outputs are selected as source (R201, R202 are populated and R198, R199 are remove) as shown in Figure 19.
../_images/LimeSDR-XTRX_v1.3_powsel_changes.png
Figure 19. Power source selection schematcs
PCB changes
LimeSDR XTRX v1.3 is based on LimeSDR XTRX v1.2 layout. The new PCB 3D view is given in Figure 20 and Figure 21.
Figure 20: LimeSDR XTRX v1.3 board top view
Figure 21: LimeSDR XTRX v1.3 board bottom view
